TwinTurbo.NET: Nissan 300ZX forum - Re: CEL light flashing is it reporting a fault code.
R3spawnn
on May 10, 2021 at 3:57 PM
CEL light flashing is it reporting a fault code. (n/m)
posted by Bernie (NoVA)
on May 10, 2021 at 12:39 PM
Cel stays solid when I start up. When I run data scan the only code I’m getting is 14. There are times when I start and the AT check light goes solid for 2 seconds then blinks 16 equal times.
Code 14.......
R3spawnn
18:48:59 05/06/21
Re: Code 14.......
R3spawnn
18:57:26 05/06/21
Re: Code 14.......
R3spawnn
19:28:13 05/06/21
Even tho the speedo is working, that could be where the
Polishzx
20:43:39 05/06/21
Re: Even tho the speedo is working, that could be where the
R3spawnn
21:19:51 05/06/21
Re: Re: Even tho the speedo is working, that could be where the
R3spawnn
21:37:58 05/06/21
Re: Re: Re: Even tho the speedo is working, that could be where the
itsa300zx
22:02:30 05/06/21
Re: Re: Re: Re: Even tho the speedo is working, that could be where the
R3spawnn
22:18:14 05/06/21
Clusters need to match - if it was not from a automatic
12:38:22 05/10/21
R3spawnn
10:11:28 05/08/21
See if techno@comcast.net still works
Zxpress
11:07:33 05/08/21
Re: See if techno@comcast.net still works
R3spawnn
16:24:19 05/08/21
Re: Re: See if techno@comcast.net still works
Zxpress
17:28:27 05/08/21
R3spawnn
21:51:03 05/06/21
12:39:29 05/10/21
Re: CEL light flashing is it reporting a fault code. -
R3spawnn
15:57:58 05/10/21
Does the "new" cluster have an "auto" light between the
12:40:23 05/10/21
Re: Does the "new" cluster have an "auto" light between the
R3spawnn
15:55:06 05/10/21
The grease is in those connectors on purpose. Don't clean it (n/m)
12:35:50 05/10/21
